Brief Description: Throttle Quadrant to Seat & Cables
Mounted plate to seat and drilled last two holes and tighten down. I have had this thing apart so many times.
Made sure all slack out and minimum settings on adjustment points on throttle cable and marked cable. Tighten down cable to throttle arm and assembled friction disks. Then to pre rotator cable and did the same. This thing has to go together like a stack of pancakes.
Checked pre rotator and throttle for settings and everything good. Put shell cover on and its lookin good.
