Got the idea form one of Stein Air video to make a semi-permanent connection. The Pulsar NSP navigation lights kit supplies Molex type pins and block. The block was too big to go through hole in the vertical stabilizers. I use the pins and heat shrink to make the connections. If I ever need to replace or dismantle all I will have to do is cut the heat shrink in the middle and pull the Molex pins apart. Tested system with nine volt battery everything checked out and the tail boom back is now complete.
