Outside vertical stabilizers Strobe/Positioning Lights mounted and prep work for wiring from horizontal stabilizers done.
Light kit comes with flat inline Molex connectors. Need to call S.C. about best location for connectors.
Note: Make sure that light mount is not stressed out of shape. Light will not fit onto tabs if it is. Put one on right but had to loosen the other for proper fit. Blue loctite use on screws.
