The extended range tanks proved to be a little time consuming to install. Lining up both so fill caps straight up and tanks slop to the front by less than one degree. Side to side also looks good.
Use steel o-clips on everything except the filters for ease in changing them out.
Note: Filters did not have direction of flow on them. Put them in so screen in them will be pushed to small diameter side of filter as fuel flows thru them.
