Brief Description: Now it's starting to take shape
Big day, gear on and keel plate torque. Two issues mounting brake calipers and disk that wasted at least one hour. Trying to start screws from under the disk cut out. Gave up and thinking I’d have to spit the caliper to start them. Caliper and disk have to go on axle before wheel too. The solution was simple, start the screws through the hole that disk mounts to hub.
Darn it anyway, mad at myself for not seeing this simple assembly. Started notes in manual for revision and assembly of M912.
Upper seat supports assemble and installed. Fuel tank set in place for foams location. Started on roto controls at main work bench. Just can’t put seat on without fuel tank and rotor control complete.
