Tolliver's RV7A Factory
Date:  9-9-2005
Brief Description:  Parts Fabrication - Seat Backs
Cut off another hinge 16 inches. I used the top and bottom angles to match drill the holes. Clecoed the bottom one in place. Then used the top most one to backdrill into the seat back for the hinged back brace. Also used the other side of the hinge backdrill the seatback brace.Started on the other seat back using the same process again.
