Tolliver's RV7A Factory
Date:  9-12-2004
Number of Hours:  4.00
Brief Description:  Rudder Skeleton
Cut the scrap area off of the rudder bottom brace. Fabricated the bottom rear shim and the 2 bottom strips. Final drilled holes in the stiffener plates and the rear rudder spar. Clecoed everything together and attached and final drilled left and right skins. Time to disassemble and deburr and dimple.
