Tolliver's RV7A Factory
Date:  5-25-2004
Brief Description:  Front Spar
Continued work on front spar. Made the 6 degree bends in the angle stiffeners. Final drilled and deburred inboard holes. OUCH! made my first boo boo.... when clipping out the material to remove from HS-702 I drilled the left side correctly and then drilled the right side on the outboard side. I don't know why I did it.... STUPID! Calling Vans tomorrow to reorder a new HS-702.
