RV-7 Construction
RV-7
Drilled right HS-405 ribs and nose ribs to spar
Plans were sketchy here. I lined the nose rib up with the skin and used that as a reference to drill the HS-405 rib to the spar and HS-710 and 714 angles. It turned out pretty good.
Fitting up the ribs to the spar and skin
Looking like an airplane part
Looks like a good fit
CX7 Home
RV-7 Home
392
136
