RV-7 Construction
Date:  3-10-2005
Number of Hours:  3.00
Brief Description:  Drilled right HS-405 ribs and nose ribs to spar
Plans were sketchy here. I lined the nose rib up with the skin and used that as a reference to drill the HS-405 rib to the spar and HS-710 and 714 angles. It turned out pretty good.
Fitting up the ribs to the spar and skin
Looking like an airplane part
Looks like a good fit
