DANIEL'S WEB SITE
Date:  7-21-2008
Brief Description:  Final alignment
Checked and fine tuned the cyclic and collective alignment. Set up cyclic about 4 degrees to the right so stick will "fall to hand" better. Also checked pitch horn position. Finally, checked for teeter total travel and will have to cut the lower blade retention straps twice as they hit the mast and I cannot mark the 7.25 degree point for cutting.
