DANIEL'S WEB SITE
Exec 162
Installed the main belly pan
Final installed the main belly pan. Measured for the cyclic boots I will make. Installed the transponder antenna. Final installed the static line tubing. Installed the position lights and the fuel drain valve.
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
