DANIEL'S WEB SITE
Exec 162
Various cleanup items
Drilled holes for and installed the static ports. Removed the cardboard from the bottom of the radiator. Removed some heat shielding from bottom of engine and located oil leak. It was the locknut on the oil pressure adjuster.
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
