DANIEL'S WEB SITE
Exec 162
Hoses and sump
Installed coolant hoses except those going to the sump/heat exchanger. Drilled and installed the oil filter bracket. Fabricated the sump bracket. Installed the lower body shell to check for sump clearance to the body.
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
