DANIEL'S WEB SITE
Exec 162
Chain Oil Bath
Final installed the bottom of the chain oil bath. Retensioned the main drive belts as had to remove front bolt from the upper engine mount for access to chain oil bath front bolt. Also installed safety wire on the main sprocket to hub bolts.
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
