Received new engine mount. Drilled holes and mounted it. Sent it out for powder coatinge. Fabricated spacers for mount. Required .25" spacer. Made 4 @ .05" and one @ .0625". Will see if that is okay. Also made spacers for between engine mount and lower ring to level it. Also test installed the water pump and alternator. Need some 1/2" washers for alternator.
