DANIEL'S WEB SITE
Exec 162
Cyclic Control
Drilled hole for for and aft control and installed the cyclic control cables. Also drilled holes for the stop rivets in the directional control and cyclic control systems. Cut out hole for bottom engine air scoop and trimmed the fresh air NACA duct.
Cyclic cables at head
Cyclic cables at control rod
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
