DANIEL'S WEB SITE
Exec 162
Fitting of Main Rotor Mast
Aligned mast, elongated holes in frame for upper mast bearing plate. Drilled one lower mast bearing plate bolt hole (broke bit).
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
