DANIEL'S WEB SITE
Exec 162
3 & 4
Sections 3 and 4
Fit the lower engine mount and the fuel system mount tube and drilled the Ground handling J-bars. Will need a nominal 1/4" spacer between the engine mount rubber ring and the engine. NOTE: Log was lost when hard drive crashed.
View of lower engine mount
View showing fuel system mount
Exec 162 Home
1114
Airframe and Landing Gear
Clutch assembly
Control Systems
Cooling System
Electronics
236
Hardware
Heat Shielding
Instruments
lower engine mount
Main Rotor
Power train
Systems
Tail Boom
Workshop and Inventory
