Ran the wire harnesses from the wing roots forward to under the panel. Routing all aft wiring forward to under the panel. Began installing the pins onto the wires and then into the appropriate CPC plugs. Routing the wires and plugs so they are out of the way. Installed the propellar onto the engine so I can begin cowl work.
