The passenger headset jack harnesses were too long and would have required me to coil them up and store them somewhere. Rather than take up space and unneeded weight, I elected to shorten those harnesses and route them along the tunnel to the arm rest console. Also I needed to create a second access point for the harnesses to exit the tunnel and come up into the arm rest console. I did this the same way I did the forward access hole the allows the harnesses to pass into the tunnel. Also I attached the fuel flow wire to the red cube which lies in the fwd tunnel.
