DENNIS'S WEB SITE
Date:  9-5-2015
Number of Hours:  6.50
Brief Description:  Wings rigging
Spent the day finishing attaching the left fuel tank to the main spar. Then ran both aileron push rods and secured them to their respective bellcranks. Some rubbing of the aileron pushrod assembly against the inbd aileron hinge bracket, however others have noted this to disappear after complete rigging of the ailerons. I attached the aileron trim servo to the aileron push rod and to the associated inspection plate. I torqued all bolts and marked them with red paint. I removed the coaxial cable from the left wing. Only the right wing tip has a VOR antenna, so won't need coaxial in the left wing. I then placed the inspection covers onto the wing. Next move will be to move the wings upstairs with their wing cradle and eventually mount them for fit onto the plane.
