Daniels Web Site
Date:  3-2-2013
Number of Hours:  4.00
Manual Reference:  7-6 / OP-7
Brief Description:  Vent Lines and Out Board Cap.Sending Plate
Installed the out-board Capasitive Sender Plates, modified snap bushings internal tank wire run. Installed vent lines in both tanks & started running wire to the in-board sender plate. Realized I can't go much further until I get a "real" torque wrench. I'd like to get the AN fitting bulkhead nuts sealed & torqued down before installing the inboard rib. It's hard to pallet buying a $200.00 torque wrench... Oh well, it will be handy when it comes to FWF / engine work. I'll order it tomorrow.
OB Sender plate
OB Sender plate
Vent lines in & wire ran per plans
Vent lines.
Vent lines.
