HS DONE!!! Well, the final riveting took a bit longer then the 2-3 hours I expected. I only removed one rivet for replacement. It was a tad high on the flush side. I am so glad I chose to build the VS first to get my skills back up to par... Well, actually when I was doing the A&P appenticeship, they never taught how to build a plane from scratch and I had only to set a couple hundred rivets during that time. The HS turned out beautiful!!!!
