Brief Description: HS Disassembly & Prep for Final Assembly
Pulled apart the HS, marked the placement of all the parts.... Deburr, deburr, deburr. Just a ccouple more pieces to finish before priming. I'll finish those later in the week as I don't plan on priming/painting till the weekend. I'm going to try a different approach on dimpling everything. I'm going to prime first then dimple after the primer sets. I've heard a ton of rave reviews on swapping these steps... Parts tend pull together tighter... We shall see!
