Brief Description: Pitot Tube installation & Wing Tip
The fiberglass wing tip is a bit challenging. I want a nice fit around the leading edge of the wing. No gap. I have the bottom of the tip drilled and will flp it over before drilling the top. The gap at between the back of the tip and the spar? Not sure it is supposed to be there. Maybe the wing tip was cut wrong. Will check with Zenith Air this week.
Pitot tube started out rough but ended up OK.
The crimping tool work so much better than I anticipated. Bottom wing tip angle in-place.
I got a start on the wing tip. Not quite ready to accept the fit.
