Labeled shrink tubing and crimped eye connectors to 6 gauge copper wire to run from battery ground to engine ground at starter. Cushion clamp used to support cable at midpoint. Engine side also crimped with 14 gauge green wire to provide engine ground in firewall forward area for other equipment (RDAC, cooling pump, ignition, etc ).
