Copied and scaled vent detail P. Mounted to a foam board to use as a cutout template. Clamped a straight end parallel to the fuselage as a guide.Difficult to location the break in the cowling in drawing XNB-P11. When set against fiberglass vent, bottom angle didn't fit correctly. Will trim foam template to better match fiberglass vent.
