Brief Description: Bottom Cowling Attach Hinge Rework
Rework of prior cowling hinge placement. Fit and marked hinge half on cowl side with cowling anchored to prop hub fixture. Marked approximately 1/8" from center of hinge knuckle and 1/8" closer to knuckle edge. Drilled with #40, Cleco'd and removed cowling assembly for updrilling with #40, deburred. Used alternating soft solid rivets for 1/2 the hinge holes and pulled CPP-44 rivets for the other half of the hinge attchement holes. Cowling fit is much improved over previous effort.
