Dr. Pete's Xenos Build
Sonex XenosB
Communications
6-30-2018
ELT Antenna Mount
Made ELT antenna mount angle from 1/8" scrap. Initial mounting location appeared as the location would interfere with fiberglass tip and mouning nutplates,
Removed and remounted centered on rib. Moved RG-58 through hole behind antenna mount angle.
Initial mount
Relocated mount
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
