Explored, discussed, and tested several ELT mounting locations in the mixer assembly area with reach of the mixer access cover. Condiderations pointed out in the ELT manual included forward orientation and not more than 10 degrees from horizontal.
Plan drawings indicate that longeron and shoulder harness attachment web provide excellent orientation. Discussed several opportunities to add flanged material and mount ELT, however adding two pieces of scrap to match londeron thickness would provide a flat mounting position under the sholder strap web.
