Drilled faillead hole into phenolic blocks cut and supplied by Interstate Plastics. Used a 3/8" pilot followed by a 3/4" step drill through both sides.
Plans incorrectly indicate the insert is 3/4" in length. The AS part is 1" long.
Snap ring pliers work well for easy assembly of nylon lead guides.
