Dr. Pete's Xenos Build
Date:  5-5-2017
Number of Hours:  2.50
Manual Reference:  XNB-C02
Brief Description:  Finish First Rudder Pedal Block
When attempting to finish the second block, found that the paddle bit shaft had bent enough to wobble when starting to drill. Purchased a Forstner bit at HD to see if it will finish the 1" hole.
Step drill to 1 inch
Bent paddle drill damage
Paddle to clear 1 inch hole
