Dr. Pete's Xenos Build
Sonex XenosB
XNB-F23
Tail Post Test Fitting
Test fit tailpost channel and Y support.Very tight between channel and Y stack. No room to Cleco the tailpost channel for the purpose of aligning all Y sectons, channel, and tailwheel mount. Will use -03 foreward Y fitting for bolt hole alignment.
Test fit port stabilator briefly to check fit.
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
