Dr. Pete's Xenos Build
Date:  4-6-2019
Number of Hours:  1.50
Brief Description:  Fuel shutoff valve actuator
Cut an angle from scrap 1/8" 6061-t6 for riveting to the brass 1/4 turn ball valve. The extension will be used as a lever arm for a panel-mount shutoff.
Removed the 1/8" x AN-3 fitting from the tank 'woops' fitting and replaced it with a 1/8" brass plug.
