Rivet top hinge to right wingtip. Dimpled inboard leading edge and used AD4-4 flush with solid button head on trailing edge. Countersunk fiberglass tip for all flush solid rivets.
**Update** discovered after installation my error installing the MS20257 rolled knuckle hinge tip attach hinge rather than a MS20001 extruded knuckle hinge. Thank you EAA homebuilt information!
