Fabricated a short mounting bracket to brace the turbocharger radiator against an engine mount tube. Incorrectly fabricated the first bracket with two nutplates. Second attempt used a single #10 nutplate for mounting to a cushion clamp, with the #8 nutplate attached to the radiator plenum securing it to the bracket. The arrangement provides a three-point mount for the radiator. Cut several pieces of rubber tubing to connect the pump and radiator.
