Crank placed in freezer for 24 hours prior to assembly. 1715 Timing gear and prop hub heat soaked in oven at 500degF for two hours. 1930 Main bearing #1 oil supply hole enlarged to 1/8", outbord end chamfered slightly. Assembled with JEG's assembly lube, part number: 555-28000. Engine assembly stand slide bolt was loose resulting in crank falling onto my foot/toes after assembly. 2030 Finish
