Dr. Pete's Xenos Build
Date:  10-20-2019
Number of Hours:  1.00
Brief Description:  Mount radio and AHRS
Drilled mount location for AHRS and V16 radio to auxillary support/mount fit between panel and sub-panel.
Seperating ground connections to two blocks. EFIS, AHRS, and related to one ground block and radio and accessory grounds to a seperate ground block.
Will run individual grounds from battery to each ground block.
