Dr. Pete's Xenos Build
Sonex XenosB
AeroVee turbo
Adjust turbo cooling lines
Moved a cushion clamp on the filter to turbo oil line to reduce conflict with turbo cooling line at the thermal switch. Used an AN6 flare to barb fitting for routing turbo cooling tubing into catch tank.
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
