The tubo cooling circuit pump outlet tubing requires reducing the pump outlet from x/x" to y/y" then to z/z" to connect with AN6 fitting on turbocharger bearing block. Used Oetiker clamps crimped with end cutting pliers to secure barb connections. Ensured the crimp ears are visible for inspection as Oeticker type clamps permit visual inspection of clamp tightness. A hose clamp will be used to attach cooling hose at the pump outlet to enable easier removal of outlet tubing assembly.
