Brief Description: Install grounding strip on battery subpanel
Located 10 point grounding strip made from a piece of copper bus bar and a 5x2 tab strip. Drilled and deburred location on bottom of battery box subpanel. Used 1/8" soft aluminum rivets to secure to panel. Made up connection between master contactor and 4 point fuse holder with 14 gauge stranded wire and Wirefy terminal ends. Heat shrink on Wirefy looks like a near waterproof connection. Tested master contactor by wiring to an adjustable power supply and grounding contactor to grounding strip.
