Dr. Pete's Xenos Build
Date:  4-27-2019
Number of Hours:  0.50
Manual Reference:  XNB-L01
Brief Description:  Mount tailwheel
Continued to ream the tailwheel socket mounting hole in small increments to get a good fit for the #1 taper pin.
The assembly has a bit of movement from the forward mount that used a simple bolt rather than a taper pin. Will try some aluminum shims to remove the movement.
Horizontal alignment apprears to be within a few degrees.
Steering geometry (push rod anchor holes) will need adjusting to find the optimal movement that gets the tailwheel to unlock.
Flyboys tailwheel mount
Assembly with 6
Assembly with 6" tailwheel
