Layout, cut, bend a piece of scrap 0.0285 material for use as a sub-panel to mount beteween the port-side engine mount tubes. Bent two sides to add rigidity. Layout, drilled and install nutplates for mounting to cushion clamps on the 3/4" motor mount tubes. Cut a piece of U-channel to support RDAC mounting angles.
