Brief Description: Remove flashing in cylinder heads
As demonstrated by Bob Mica at Jeff Schultz' Firewall Forward seminar in Lee's Summit, used a 3/16" drill bit to open up the area on the AeroVee's cylider head beteen the cylinders. The starboard head had a small space, however the port side was completly closed off by casting flash. Drilled a series of holes in the area trying to overlap and use the side of the bit to do a limited amount of 'milling' between holes. Used a medium thickness flat file to smooth area between hole. Drill chuck marked the ends of the cooling adjacent to the flash removal.
