Cut a scape section of C-channel to stiffen oil filter and turbo cooling reservoir mounting plate. Aligned and drilled mounting holes for oil filter. Left inlet hose length and routing. Outlet hose length needs shortend.
Removed turbocharger extended sump, using original flat outlet. Replaced 45 elbow with a straight fitting. Adjusted pickup hose mounting clamps.
