While attempting to attached the bottom cowling found that the 90 degree bend in the AN6 braided oil return line to the oil pump interfered with the cowling. Removed the cushion clamp that was holding the line to the engine to let the oil line fitting rotate. Will need to remove the second clamp and draw some of the line toward the rear when the clamps are refit to the engine.
It would be desireable to locate the turbocharger coolant pump near the radiator on the starboard side, leaving the port side for electrical and carburetor.
