Brief Description: Remake port-side accessory mount
Found that mounting the coolant tank would interfere with the oil filter lines. Began remaking the mounting plate attaching the turbocharger cooling fluid bottle and oil filter. Adding folded tabs to increase strength. Sizing plate to fit between engine struts rather than resting behind struts to help the coolant tank fit. Will likely need to change the length of the oil lines.
