Brief Description: Remake of port-side wheelpant mounting plate
Recut the port-side wheelpant mounting plate from 1/8" stock. Factory make plate, modified to fit Tracey O'Brien axles, was redrilled to rotate plate paralled with the airframe. Rotation required cutting/extending hydraulic connection access. Access hole moved too close to the top of the mounting plate, resulting in the decision to remake the plate. Recut to be an inch higher, 7/8" axle hole to accomodate TOB axle mount. Align drilled with TBO anti-torque flange.
