Instaled aeroquip straight fitting on AN6 braided hose and connected to 45 degree elbow on turbocharger drain. Measured length to oil pump, cut and installed 90 degree aeroquip fitting. Secured line to bottom of engine with cushioned clamp, and to motor mount member with double cushion clamps. Adjusted oil line between clamps to free contact with exhaust and engine mount. Used technique demonstrated by Dick Koeler in an EAA video for holding cushion clamps together.
